ANR-UL-25A
ANR-UL-25A
    OPTIFUSE
    Blade,ATO/ATC
    FUSE AUTO 25A 32VDC BLADE
ANR-UL-25A 数据手册
Type ANR-UL Automotive Blade Fuse Standard w/ UL Approval www.optifuse.com (619) 593-5050 Specifications: · Voltage: 32V DC · Amperage: 1A, 2A, 3A, 4A, 5A, 7.5A, 10A, 15A, 20A, 25A, 30A, 35A, 40A · Body: Nylon PA66 · Terminals: Zinc Alloy, Tin plated · Interrupt Rating: 1000A @ 32V DC Agency Standards and Listings: Designed to meet ISO 8820-3 Standards. Part Number Amperage Body Color ANR-UL-1A ANR-UL-2A ANR-UL-3A ANR-UL-4A ANR-UL-5A ANR-UL-7.5A ANR-UL-10A ANR-UL-15A ANR-UL-20A ANR-UL-25A ANR-UL-30A ANR-UL-35A ANR-UL-40A 1A 2A 3A 4A 5A 7.5A 10A 15A 20A 25A 30A 35A 40A Black Gray Violet Pink Tan Brown Red Blue Yellow Clear/White Green Dark Green Orange Voltage Drop 250 mV 225 mV 200 mV 200 mV 175 mV 150 mV 140 mV 125 mV 125 mV 125 mV 120 mV 120 mV 120 mV Time Characteristics: % of Rated Min Hold Max Hold Current Time Time 100% 100h 135% 750ms 1800s 200% 150ms 5s 350% 40ms 500ms 600% 20ms 200ms Mechanical Dimensions: mm (Inches) Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev A 11/2018 - Page: 1/1 Code J01-01H
ANR-UL-25A 价格&库存
很抱歉,暂时无法提供与“ANR-UL-25A”相匹配的价格&库存,您可以联系我们找货
