ANR-20A
ANR-20A
    OPTIFUSE
    Blade,ATO/ATC
    FUSE AUTO 20A 32VDC BLADE
ANR-20A 数据手册
Type ANR Automotive Blade Fuse Standard www.optifuse.com Specifications: · Voltage: 32VDC · Amperage: 1A, 2A, 3A, 4A, 5A, 7.5A, 10A, 12A, 15A, 20A, 25A, 30A, 35A, 40A · Body: PA 66 · Terminals: Zinc alloy · Designed to meet SAE and ISO 8820 Standards. · Interrupt Rating – 1000A @ 32 VDC · Operating Temperature: -40°C ~ +105°C % of Rated Current 110% 135% 200% Time Characteristics: Min Hold Time 100h ~ ~ Max Hold Time ~ 1800s 5s Part Number ANR-1A ANR-2A ANR-3A ANR-4A ANR-5A ANR-7.5A ANR-10A ANR-12A ANR-15A ANR-20A ANR-25A ANR-30A ANR-35A ANR-40A (619) 593-5050 Amperage 1A 2A 3A 4A 5A 7.5A 10A 12A 15A 20A 25A 30A 35A 40A Body Color Black Gray Violet Pink Tan Brown Red Light Red Blue Yellow Clear Green Blue Green Orange Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev E 12/2018 - Page: 1/2 Code H02-01H Type ANR Automotive Blade Fuse Standard www.optifuse.com (619) 593-5050 Temperature Rating Curve Time Current Curve Note: All specifications subject to change without notice. Rev E 12/2018 - Page: 2/2 Code H02-01H
ANR-20A 价格&库存
很抱歉,暂时无法提供与“ANR-20A”相匹配的价格&库存,您可以联系我们找货
