ANR58-500MA
ANR58-500MA
    OPTIFUSE
    Blade,ATO/ATC
    REGULAR (ATO/ATC), 58V 500MA-UL
ANR58-500MA 数据手册
Type ANR58-UL Automotive Blade Fuse Standard - Voltage 58V w/ UR Approval www.optifuse.com Specifications: · Voltage: 58V DC · Amperage: 500mA, 1A, 2A, 3A, 4A, 5A, 6A, 7A, 7.5A, 8A, 10A, 12A, 15A, 16A, 20A, 25A, 30A, 35A, 40A · Material: Body – Nylon 66 with 30% Fiber Glass UL94V-0 Terminals – Copper Alloy, Tin plated · Interrupt Rating: 1000A 58VDC (619) 593-5050 Agency Standards and Listings: Mechanical Dimensions: Inches [mm] Standards: UL248-1 Special Purpose Fuse Time Characteristics: % of Rated Max Hold Min Hold Time Current Time 100% Carry (35A~40A) --110% Carry (500mA~30A) --135% 750ms 3600s 200% 150ms 60s 350% 40ms 1s 600% 10ms 100ms Part Number ANR58-UL-500MA ANR58-UL-1A ANR58-UL-2A ANR58-UL-3A ANR58-UL-4A ANR58-UL-5A ANR58-UL-6A ANR58-UL-7A ANR58-UL-7.5A ANR58-UL-8A ANR58-UL-10A ANR58-UL-12A ANR58-UL-15A ANR58-UL-16A ANR58-UL-20A ANR58-UL-25A ANR58-UL-30A ANR58-UL-35A ANR58-UL-40A Warning: Amperage 500mA 1A 2A 3A 4A 5A 6A 7A 7.5A 8A 10A 12A 15A 16A 20A 25A 30A 35A 40A Body Color Dark Blue Black Gray Violet Pink Tan Light Red Light Orange Brown Light Yellow Red Light Pink Blue Light Green Yellow Clear Green Blue Green Orange Voltage Drop (mV) 150 125 120 110 110 110 ----90 --90 --90 --90 80 80 70 70 Cold Resistance 290 mΩ 100 mΩ 43.0 mΩ 30.0 mΩ 22.0 mΩ 16.0 mΩ ----9.00 mΩ --6.50 mΩ --4.00 mΩ --3.00 mΩ 1.90 mΩ 1.65 mΩ 1.45 mΩ 1.25 mΩ I2T 0.3 2.3 9.6 16.2 36.8 62.5 ----73.1 --210 --270 --360 813 1530 1960 3200 -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev B 10/2018 - Page: 1/2 Code G02-01H Type ANR58-UL Automotive Blade Fuse Standard - Voltage 58V w/ UL Approval www.optifuse.com (619) 593-5050 Time Current Curve Graph Note: All specifications subject to change without notice. Rev B 10/2018 - Page: 2/2 Code G02-01H
ANR58-500MA 价格&库存
很抱歉,暂时无法提供与“ANR58-500MA”相匹配的价格&库存,您可以联系我们找货
