ANT80-2A
ANT80-2A
    OPTIFUSE
    Blade,Micro
    FUSE AUTO 2A 80VDC BLADE MICRO
ANT80-2A 数据手册
Type ANT80 Automotive Blade Fuse Tiny (Micro2 style) www.optifuse.com Specifications: · Voltage: 80V DC · Amperage: 1A, 2A, 3A, 4A, 5A, 7.5A, 10A, 15A, 20A · Body Material: Nylon with 25% Fiberglass · Cover Material: Nylon with 25% Fiberglass, Red · Metal Material: Copper Alloy, Tin plated · Interrupting Rating: 1000A @ 80 VDC Time Characteristics: % of Rated Current Min Hold Time Max Hold Time 110% 135% 200% 350% 600% 100h 750ms 150ms 40ms 20ms 1800s 5s 500ms 100ms Part Number ANT80-1A ANT80-2A ANT80-3A ANT80-4A ANT80-5A ANT80-7.5A ANT80-10A ANT80-15A ANT80-20A (619) 593-5050 Amperage 1A 2A 3A 4A 5A 7.5A 10A 15A 20A Body Color Black Gray Violet Pink Tan Brown Red Blue Yellow Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev A 07/2018 - Page: 1/1 Code G02-01H
ANT80-2A 价格&库存
很抱歉,暂时无法提供与“ANT80-2A”相匹配的价格&库存,您可以联系我们找货
