ANX58-UL-50A
ANX58-UL-50A
    OPTIFUSE
    Blade,Max
    FUSE AUTO 50A 58VDC BLADE MAX
ANX58-UL-50A 数据手册
Type ANX58-UL Automotive Blade Fuse Maxi Size www.optifuse.com Specifications: · Voltage: 58VDC · Amperage: 20A, 25A, 30A, 35A, 40A, 50A, 60A · Material: Cover: Polycarbonate, UL94V-0 Body – Nylon 66 with 25% Fiber Glass, UL94V-0 Metal – Copper Alloy, gal. Sn Element – Zinc, Sn plated · Interrupt Rating – 1000A @ 58 VDC Standards: According to SAE J1888 (619) 593-5050 Time Characteristics: % of Rated Min Hold Max Hold Current Time Time 100% 100h 135% 60s 3600s 200% 2s 60s 350% 200ms 7s 600% 40ms 1s Agency Standards and Listings: Part Number ANX58-UL-20A ANX58-UL-25A ANX58-UL-30A ANX58-UL-35A ANX58-UL-40A ANX58-UL-50A ANX58-UL-60A Amperage Body Color 20A 25A 30A 35A 40A 50A 60A Yellow Gray Green Brown Orange Red Blue Voltage Drop (mV) 110 110 100 100 90 90 85 Cold Resistance 3.65 mΩ 2.90 mΩ 2.20 mΩ 1.85 mΩ 1.60 mΩ 1.17 mΩ 1.05 mΩ I2T 1320 2188 3330 4533 6240 10000 14400 Mechanical Dimensions: Inches [mm] Note: All specifications subject to change without notice. Rev A 01/2019 - Page: 1/2 Code G02-01H Type ANX58-UL Automotive Blade Fuse Maxi Size www.optifuse.com (619) 593-5050 Time Current Curve Graph Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev A 01/2019 - Page: 2/2 Code G02-01H
ANX58-UL-50A 价格&库存
很抱歉,暂时无法提供与“ANX58-UL-50A”相匹配的价格&库存,您可以联系我们找货
