APM-AF-20A
APM-AF-20A
    OPTIFUSE
    Blade,Miniature
    FUSE AUTO 20A 32VDC BLADE MINI
APM-AF-20A 数据手册
Type APM-AF Automotive Blade Fuse Miniature – Access-A-Fuse www.optifuse.com (619) 593-5050 Specifications: · Voltage: 32V DC · Amperage: 10A, 15A, 20A · 10, 15, or 20 amp primary circuit with a 3, 5, or 7.5 amp stationary fused auxiliary connection · Aux. Tab: 3/16” (0.187”) Part Number APM-AF-10A APM-AF-15A APM-AF-20A Primary Fuse Amperage 10A 15A 20A Time Characteristics: % of Rated Current Min Hold Time 110% >100h 135% 750ms 200% 150ms 350% 40ms 600% 20ms Auxiliary Fuse Amperage 3A 5A 7.5A Body Color Red Blue Yellow Max Hold Time 1800s 5s 500ms 200ms Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev A 12/2011 - Page: 1/1 Code A03-01H
APM-AF-20A 价格&库存
很抱歉,暂时无法提供与“APM-AF-20A”相匹配的价格&库存,您可以联系我们找货
