ANX80-UL-60A
ANX80-UL-60A
    OPTIFUSE
    Blade,Max
    FUSE AUTO 60A 80VDC BLADE MAX
ANX80-UL-60A 数据手册
Type ANX80 Automotive Blade Fuse Maxi Size www.optifuse.com Specifications: · Voltage: 80VDC · Amperage: 20A, 25A, 30A, 35A, 40A, 50A, 60A · Material: Cover: Polycarbonate, UL94V-0 Body – Nylon 66 with 25% Fiber Glass, UL94V-0 Metal – Copper Alloy, gal. Sn Element – Zinc, Sn plated · Interrupt Rating – 1000A @ 80 VDC · Standards: According to SAE J1888 Part Number ANX80-20A ANX80-25A ANX80-30A ANX80-35A ANX80-40A ANX80-50A ANX80-60A Amperage 20A 25A 30A 35A 40A 50A 60A Body Color Yellow Gray Green Brown Orange Red Blue Voltage Drop (mV) 110 110 100 100 90 90 85 Cold Resistance 3.65 mΩ 2.90 mΩ 2.20 mΩ 1.85 mΩ 1.60 mΩ 1.17 mΩ 1.05 mΩ (619) 593-5050 Time Characteristics % of Rated Min Hold Max Hold Current Time Time 100% 100h 135% 60s 3600s 200% 2s 60s 350% 200ms 7s 600% 400ms 1s I2T 1320 2188 3330 4533 6240 10000 14400 Mechanical Dimensions: Inches [mm] Note: All specifications subject to change without notice. Rev D 08/2018 - Page: 1/2 Code G02-01H Type ANX80 Automotive Blade Fuse Maxi Size www.optifuse.com (619) 593-5050 Time Current Curve Graph Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev D 08/2018 - Page: 2/2 Code G02-01H
ANX80-UL-60A 价格&库存
很抱歉,暂时无法提供与“ANX80-UL-60A”相匹配的价格&库存,您可以联系我们找货
