APM-UL-2A
APM-UL-2A
    OPTIFUSE
    Blade,Miniature
    FUSE AUTO 2A 32VDC BLADE MINI
APM-UL-2A 数据手册
Type APM-UL Automotive Blade Fuse Miniature w/ UL Approval www.optifuse.com (619) 593-5050 Specifications: · Voltage: 32V DC · Interrupt Rating: 1000A @ 32V DC · Amperage: 2A, 3A, 4A, 5A, 7.5A, 10A, 15A, 20A, 25A, 30A · Terminals: Silver plated Agency Standards and Listings: Designed to meet SAE J2077 and ISO 8820-3 Standards. Tested under UL 275A standard. Part Number APM-UL-2A APM-UL-3A APM-UL-4A APM-UL-5A APM-UL-7.5A APM-UL-10A APM-UL-15A APM-UL-20A APM-UL-25A APM-UL-30A Amperage 2A 3A 4A 5A 7.5A 10A 15A 20A 25A 30A Body Color Gray Violet Pink Tan Brown Red Blue Yellow Clear Green Time Characteristics: % of Rated Min Hold Current Time >100h 110% 750ms 135% 150ms 200% 80ms 350% 30ms 600% Max Hold Time 600s 5s 250ms 100ms Mechanical Dimensions: mm (Inches) Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev B 06/2018 - Page: 1/2 Code G02-01H Type APM-UL Automotive Blade Fuse Miniature w/ UL Approval www.optifuse.com (619) 593-5050 Time Current Curve Graph Note: All specifications subject to change without notice. Rev B 06/2018 - Page: 2/2 Code G02-01H
APM-UL-2A 价格&库存
很抱歉,暂时无法提供与“APM-UL-2A”相匹配的价格&库存,您可以联系我们找货
