APR-UL-35A
APR-UL-35A
    OPTIFUSE
    Blade,ATO/ATC
    FUSE AUTO 35A 32VDC BLADE
APR-UL-35A 数据手册
Type APR-UL Automotive Blade Fuse Standard w/ UL Approval www.optifuse.com (619) 593-5050 Specifications: · Voltage: 32V DC · Interrupt Rating: 1000A @ 32V DC · Amperage: 1A, 2A, 3A, 4A, 5A, 7.5A, 10A, 15A, 20A, 25A, 30A, 35A, 40A · Body – PA66 · Terminals – Tin plated Agency Standards and Listings Designed to meet SAE J1284 and ISO 8820-3 Standards. Part Number APR-UL-1A APR-UL-2A APR-UL-3A APR-UL-4A APR-UL-5A APR-UL-7.5A APR-UL-10A APR-UL-15A APR-UL-20A APR-UL-25A APR-UL-30A APR-UL-35A APR-UL-40A Amperage 1A 2A 3A 4A 5A 7.5A 10A 15A 20A 25A 30A 35A 40A Body Color Black Gray Violet Pink Tan Brown Red Blue Yellow Clear/White Green Dark Green Orange % of Rated Current 100% 110% 135% 200% 350% 600% Time Characteristics: Amperag Min Hold e Time 35A-40A 100h 1A-30A 100h 1A-2A 500ms 3A-40A 750ms 1A-2A 100ms 3A-40A 150ms 1A-2A 20ms 3A-40A 80ms 1A-30A 35A-40A - Max Hold Time 600s 600s 5s 5s 500ms 500ms 100ms 150ms Mechanical Dimensions: mm (Inches) Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev C 11/2018 - Page: 1/2 Code G02-01H Type APR-UL Automotive Blade Fuse Standard w/ UL Approval www.optifuse.com (619) 593-5050 Time Current Curve Graph Note: All specifications subject to change without notice. Rev C 11/2018 - Page: 2/2 Code G02-01H
APR-UL-35A 价格&库存
很抱歉,暂时无法提供与“APR-UL-35A”相匹配的价格&库存,您可以联系我们找货
