BLC-05-GTA
BLC-05-GTA
    OPTIFUSE
    FUSE BLOCK - LIMITER (MID), 300A
BLC-05-GTA 数据手册
Type BLC-05-GTA Fuse Block MID Limiter Fuses Specifications: Voltage Rating: 32VDC Max Current Rating: 300A Fuse Type: MID Limiter Fuse Base: Phenolic Laminate, Flame retarding Terminals: Steel, anti-corrosion www.optifuse.com (619) 593-5050 Hardware Specifications Item Qty Description 1 2 Bolt, M5 x L25 2 4 Nut, Hex, M5 3 2 Spring Lock washer 4 2 Flatwasher Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev A 07/2011 - Page: 1/1 Code G02-01H
BLC-05-GTA 价格&库存
很抱歉,暂时无法提供与“BLC-05-GTA”相匹配的价格&库存,您可以联系我们找货
