BLC-06B
BLC-06B
    OPTIFUSE
    FUSE BLOCK - LIMITER (MID), 100A
BLC-06B 数据手册
Type BLC-06B Fuse Block MID Limiter Fuses www.optifuse.com (619) 593-5050 Specifications: Voltage Rating: 32VDC Current Rating: 30A~100A (max.) Wire Sizes: #2-8AWG Fuse Type: MID Limiter Fuse Base: PBT (UL flame:94V-0) Cover: Nylon (UL flame: 94V-0) Terminals: M5 Nickel Plated SteelThreaded Studs and Hex Nuts Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev A 12/2011 - Page: 1/1 Code S02-01H
BLC-06B 价格&库存
很抱歉,暂时无法提供与“BLC-06B”相匹配的价格&库存,您可以联系我们找货
