Type BLC-07B
Fuse Block
MGGA Fuse Link Fuses
www.optifuse.com
(619) 593-5050
Specifications:
Voltage Rating: 32VDC
Max Current Rating: 500A
Fuse Type: MGGA Fuse Link Fuses
Base: PBT - Black
Cover: Nylon-66
Screws: Nickel plated Steel studs – M8*1.25P
Torque Rating: 20in-lb (2.25Nm) max.
Mechanical Dimensions: Inches [mm]
Warning:
-Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical
arcing and/or flame.
-Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance.
Note: All specifications subject to change without notice.
Rev B 02/2018 - Page: 1/1
Code S02-01H
很抱歉,暂时无法提供与“BLC-07B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+163.731301+21.24400
- 10+146.3130810+18.98400
- 50+137.6039650+17.85400
- 100+130.63667100+16.95000
