Type BLC-08-GT
Fuse Block
MEGA® Limiter Fuses
Specifications:
Voltage Rating: 125VAC / 500VDC
Max Current Rating: 500A
Fuse Type: MEGA® Limiter Fuse
Insulation Resistance @ 500V DC: 100M Min.
Base: Phenolic Laminate, Flame Retarding
Terminals: Steel, anti-corrosion
www.optifuse.com
(619) 593-5050
Hardware Specifications
Item
1
2
3
4
5
Qty
2
2
4
2
2
Description
Nut, Nylock 5/16-24UNF
Lock Washer, 5/16
Washer, 5/16 SAE
Nut, Hex, Normal, 5/16-24UNF
Bolt, hex cap, 5/16-24 UNF x 1.25
For Cover: See BLC-08-GTC
Mechanical Dimensions: Inches [mm]
Warning:
-Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical
arcing and/or flame.
-Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance.
Note: All specifications subject to change without notice.
Rev A 09/2013 - Page: 1/1
Code G02-01H
很抱歉,暂时无法提供与“BLC-08-GT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+161.582431+20.90500
- 10+145.8609010+18.87100
- 50+144.1140650+18.64500
- 100+138.00013100+17.85400
