BLC-09-GT
BLC-09-GT
    OPTIFUSE
    FUSE BLOCK-LIMITER ANE/ANF, 500A
BLC-09-GT 数据手册
Type BLC-09-GT Fuse Block ANE / ANF Limiter Fuses Specifications: Voltage Rating: 125 VAC, 80 VDC Max Current Rating: 500A Fuse Type: ANE / ANF Limiter Fuse Insulation Resistance @ 500V DC: 100M Min. Base: Polyester Impact/Electrical - Black with Mineral and Glass Fiber Added. ULR Certification number E40654 Terminals: Low Carbon Steel, Zinc Finish www.optifuse.com (619) 593-5050 Hardware Specifications Item 1 2 3 4 5 Qty 2 2 2 2 2 Description Nut, Nylock 5/16-24UNF Lock Washer, 5/16 Washer, 5/16 SAE Nut, Hex, Normal, 5/16-24UNF Bolt, hex cap, 5/16-24 UNF x 1.25 Tightening Torques Stainless & ASTM Steels is metric thread: Bolts M8 , Pitch: 1.25 14.2 N/mm2 8823N For Cover: See BLC-09-GTC Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev E 06/2018 - Page: 1/1 Code G02-01H
BLC-09-GT 价格&库存
很抱歉,暂时无法提供与“BLC-09-GT”相匹配的价格&库存,您可以联系我们找货
BLC-09-GT
  • 1+176.430551+22.82600
  • 10+165.0761010+21.35700
库存:35
