BLC-09-GTA
BLC-09-GTA
    OPTIFUSE
    FUSE BLOCK-LIMITER ANE/ANF, 400A
BLC-09-GTA 数据手册
Type BLC-09-GTA Fuse Block with Cover ANE / ANF Limiter Fuses www.optifuse.com (619) 593-5050 Specifications: Voltage Rating: 125 VAC, 80 VDC Max Current Rating: 400A Fuse Type: ANE / ANF Limiter Fuse Insulation Resistance @ 500V DC: 100M Min. Base: Polyester Impact/Electrical - Black with Mineral and Glass Fiber Added. ULR Certification number E40654 Terminals: Low Carbon Steel, Zinc Finish Cover: Polycarbonate UL 94V0 For Block alone: See BLC-09-GT For Cover alone: See BLC-09-GTC Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev B 04/2016 - Page: 1/1 Code G02-01H
BLC-09-GTA 价格&库存
很抱歉,暂时无法提供与“BLC-09-GTA”相匹配的价格&库存,您可以联系我们找货
