Type BLC-09
Fuse Block
ANE / ANF Limiter Fuses
Specifications:
Voltage Rating: 125VAC
Max Current Rating: 200A
Fuse Type: ANE / ANF Limiter Fuse
Base: Polyester Impact/Electrical -01528 Grey
with Mineral and Glass Fiber Added.
ULR Certification number E40654
Terminals: Low Carbon Steel, Zinc Finish
www.optifuse.com
(619) 593-5050
Hardware Specifications
Item Qty Description
1
2 Nut, Nylock 5/16-24UNF
2
2 Bolt, hex cap, 5/16-24 UNF x 1.25
3
2 Washer, 5/16 SAE
4
2 Nut, Hex, Normal, 5/16-24UNF
Mechanical Dimensions: Inches [mm]
Warning:
-Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical
arcing and/or flame.
-Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance.
Note: All specifications subject to change without notice.
Rev C 06/2018 - Page: 1/1
Code J01-02D
很抱歉,暂时无法提供与“BLC-09”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+281.240771+36.38600
- 10+251.5445410+32.54400
