BLC-106-G
BLC-106-G
    OPTIFUSE
    REG. FUSE BLOCK, 6 POLE GROUND
BLC-106-G 数据手册
Type BLC-106-G Fuse Block 6 Pole – Regular Auto Blade Type With 12 Position Grounding Block www.optifuse.com (619) 593-5050 Specifications: Max Current Rating: 25A per Circuit - 150A Max Input Max Voltage: 32VDC Fuse Type: Regular Auto Blade (APR series), Regular Automotive Circuit Breakers (ACBP4-PL and MRCBP4-PL series) Base: Polycarbonate Load-side Connection: 0.250” Quick Connect Terminals - Copper, Tin plated Line-side Connection: #10-32 stud terminal with hex nut, flat washer, lockwasher (hardware provided) Mounting: 5.5mm diameter mounting holes for #10 screws (not provided) Optional Cover available Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev B 04/2013 - Page: 1/1 Code B01-01H
BLC-106-G 价格&库存
很抱歉,暂时无法提供与“BLC-106-G”相匹配的价格&库存,您可以联系我们找货
BLC-106-G
  • 1+483.873871+62.60200
  • 10+432.3421710+55.93500
