BLC-108
BLC-108
    OPTIFUSE
    REGULAR FUSE BLOCK, 8 POLE
BLC-108 数据手册
Type BLC-108 Fuse Block 8 Pole – Regular Auto Blade www.optifuse.com (619) 593-5050 Specifications: Max Current Rating: 25A per Circuit - 150A Max Input Max Voltage: 32VDC Fuse Type: Regular Auto Blade (APR series) Base: Polycarbonate Terminals: 8 ea Copper, Tin plated 0.250” Quick Connect Terminals, 1 ea #10-32 stud terminal with hex nut, flat washer and lockwasher supplied. Mounting: 4 mounting holes for #10-32 screws (not supplied) Cover available: BLC-108-C Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev C 01/2012 - Page: 1/1 Code B01-01H
BLC-108 价格&库存
很抱歉,暂时无法提供与“BLC-108”相匹配的价格&库存,您可以联系我们找货
