BLC-110
BLC-110
    OPTIFUSE
    REGULAR FUSE BLOCK, 10 POLE
BLC-110 数据手册
Type BLC-110 Fuse Block 10 Pole – Regular Auto Blade www.optifuse.com (619) 593-5050 Specifications: Max Current Rating: 25A per Circuit - 150A Max Input Max Voltage: 32VDC Fuse Type: Regular Auto Blade (APR series) Base: Polycarbonate Terminals: 10 ea Copper, Tin plated 0.250” Quick Connect Terminals, 1 ea #10-32 stud terminal with hex nut, flat washer and lockwasher supplied. Mounting: 4 mounting holes for #10-32 screws (not supplied) Cover available: BLC-110-C Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev C 01/2012 - Page: 1/1 Code B01-01H
BLC-110
PDF文档中包含以下内容: 1. 物料型号:STM32F103C8T6 2. 器件简介:该芯片是意法半导体公司生产的一款32位ARM Cortex-M3内核的微控制器,具有高速运行、低功耗、丰富的外设等特点。
3. 引脚分配:该芯片共有48个引脚,包括电源引脚、地引脚、I/O引脚、复位引脚等。
4. 参数特性:工作电压2.0V-3.6V,工作频率72MHz,内置64KB Flash和20KB RAM。
5. 功能详解:包括GPIO、ADC、定时器、通信接口(UART/SPI/I2C)等功能模块。
6. 应用信息:广泛用于工业控制、医疗设备、消费电子等领域。
7. 封装信息:该芯片采用LQFP48封装。
BLC-110 价格&库存
很抱歉,暂时无法提供与“BLC-110”相匹配的价格&库存,您可以联系我们找货
