BLC-16-B2
BLC-16-B2
    OPTIFUSE
    1-1/4"X1/4" BLOCK-2 PINS, SNAPIN
BLC-16-B2 数据手册
Type BLC-16 Fuse Block For ¼” x 1¼” (6.3 x 32mm) Fuses Fuse Style: ¼” x 1¼” (6.3 x 32mm) Fuses Material: Body: Thermostate (UL Flame: 94V-0) Fuse Clips: Copper Alloy Tinned T:0.5mm Terminal: Copper Alloy Tinned T:0.8mm Specifications: Dielectric Strength for 60 seconds: 1200VAC Min Suitable Rated Current: 25A 250V Insulation resistance at 500V DC: 500M Min. Temperature Rise: 30 with dummy fuse, 85 with time-delay fuse Voltage Drop: 15mV Max. www.optifuse.com Part # BLC-16-B BLC-16-B1 BLC-16-B2 BLC-16-S BLC-16-S1 BLC-16-S2 (619)-593-5050 # of Terminals Pins/Legs no Bent 1 Bent 2 Bent no Straight 1 Straight 2 Straight Agency Standards and Listings: Product Dimensions: Inches [mm] Note: All specifications subject to change without notice. Rev A 06/2007 - Page: 1/2 Code: C01-02D Type BLC-16 Fuse Block For ¼” x 1¼” (6.3 x 32mm) Fuses Warning: www.optifuse.com (619)-593-5050 -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of Fuse Block with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev A 06/2007 - Page: 2/2 Code: C01-02D
BLC-16-B2
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路安全。
3. 引脚分配:共有6个引脚,分别为1脚阳极,2脚阴极,3脚发光二极管正极,4脚发光二极管负极,5脚光电晶体管输出,6脚光电晶体管负极。
4. 参数特性:工作电压3-32V,输入电流5mA,输出电流10mA,隔离电压5000V。
5. 功能详解:EL817通过光电效应实现电-光-电转换,实现信号隔离。
6. 应用信息:广泛应用于工业控制、仪器仪表、医疗设备等领域。
7. 封装信息:采用DIP-6封装。
BLC-16-B2 价格&库存
很抱歉,暂时无法提供与“BLC-16-B2”相匹配的价格&库存,您可以联系我们找货
