BLC-20A
BLC-20A
    OPTIFUSE
    1-1/4"X1/4" FUSE BLOCK. SCREWS
BLC-20A 数据手册
Type BLC-20A Fuse Block For ¼” x 1¼” (6.3 x 32mm) Fuses www.optifuse.com (619)-593-5050 Fuse Style: ¼” x 1¼” (6.3 x 32mm) Fuses Material: Body: PBT (UL Flame: 94V-0) Terminal: Nickel plated Brass Mounting: by screws Electrical: 15A 125VAC 10A 250VAC Single Fuse Blocks can be snapped together for multi-pole applications. Agency Standards and Listings: Product Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of Fuse Block with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev A 01/2008 - Page: 1/1 Code: S02-02D
BLC-20A 价格&库存
很抱歉,暂时无法提供与“BLC-20A”相匹配的价格&库存,您可以联系我们找货
