BLM-304
BLM-304
    OPTIFUSE
    MINI FUSE BLOCK, 4 POLE
BLM-304 数据手册
Type BLM-304 Fuse Block 4 Pole – Miniature Auto Blade www.optifuse.com (619) 593-5050 Specifications: Max Current Rating: 30A per Circuit - 100A Max Input Fuse Type: Miniature Auto Blade – APM, ANM Series Base: PBT (UL-Flame 94V-0) Cover: PC (UL-Flame 94V-2) Terminals: Tin Plated Brass - 0.250” Quick Connect Terminals Temperature Rating: -20° C ~ +85° C Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev C 05/2017 - Page: 1/1 Code S02-01H
BLM-304 价格&库存
很抱歉,暂时无法提供与“BLM-304”相匹配的价格&库存,您可以联系我们找货
