BLR-304-G
BLR-304-G
    OPTIFUSE
    REG. FUSE BLOCK, 4 POLE GROUND
BLR-304-G 数据手册
Type BLR-304-G Fuse Block 4 Pole – Regular Auto Blade With 4 Position Grounding Block www.optifuse.com (619) 593-5050 Specifications: Max Voltage: 32VDC Max Current Rating: 30A per Circuit - 100A Max Input Fuse Type: Regular Auto Blade – APR, APN Series Base: PBT Cover: PC (Transparent) Load-side Connection: 0.250” Quick Connect Terminals - Copper, Tin plated Line-side Connection: 2 each, M5 (SUS304) stud terminal with 2 hex nuts, flat washer, lock-washer Mounting: 4 mounting holes for #10 screws (not provided) Temperature Rating: -20° C ~ +85° C Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev A 04/2018 - Page: 1/1 Code S02-01H
BLR-304-G 价格&库存
很抱歉,暂时无法提供与“BLR-304-G”相匹配的价格&库存,您可以联系我们找货
