BLR-706
BLR-706
    OPTIFUSE
    REGULAR FUSE BLOCK, 6 POLE
BLR-706 数据手册
Type BLR-706 Fuse Block 6 Pole – Regular Auto Blade www.optifuse.com (619) 593-5050 Specifications: Fuse Type: Regular Auto Blade – APR, ANR Series Max Current Rating: 15A per Circuit - 45A Max Max Voltage: 32VDC Material: 1. Base: Nylon 66 + 15% Fiber 2. Terminals: Brass, 0.250” [6.3mm] Quick Connect Terminals 3. Sealer: NBR 4. Cover: Polycarbonate (Transparent) 5. Mounting Seal: Nylon 66 + 15% Fiber Mounting: Two (2) 5.4 mounting holes for #10 screws Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev B 04/2018 - Page: 1/1 Code B01-01H
BLR-706 价格&库存
很抱歉,暂时无法提供与“BLR-706”相匹配的价格&库存,您可以联系我们找货
