BLR-I-306
BLR-I-306
    OPTIFUSE
    REGULAR FUSE BLOCK, 6 POLE LED
BLR-I-306 数据手册
Type BLR-I-306 Fuse Block - Indicating 6 Pole – Regular Auto Blade www.optifuse.com (619) 593-5050 Specifications: Max Current Rating: 30A per Circuit - 100A Max Input Fuse Type: Regular Auto Blade – APR, ANR Series Base: PBT (UL flame: 94V-0), Black Cover: PC (UL flame: 94V-2), Transparent Push Button: POM (White) Terminals: Copper, Tin plated 0.250” Quick Connect Terminals Indicating LED – Red Temperature Rating: -20° C ~ +85° C Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev C 05/2017 - Page: 1/1 Code S02-01H
BLR-I-306 价格&库存
很抱歉,暂时无法提供与“BLR-I-306”相匹配的价格&库存,您可以联系我们找货
