BLR-I-604
BLR-I-604
    OPTIFUSE
    REGULAR FUSE BLOCK, 4 POLE LED
BLR-I-604 数据手册
Type BLR-I-604 Fuse Block - Indicating 4 Pole – Regular Auto Blade www.optifuse.com (619) 593-5050 Specifications: Fuse Type: Regular Auto Blade – APR, ANR Series Max Current Rating: 30A per Circuit - 100A Max Input Max Voltage: 32VDC IP Rating: 40 Material: Base: PBT Terminals: Copper, tin plated 0.250” [6.3mm] Quick Connect Terminals Cover: PC (Transparent) Indicating LED – Red Temperature Rating: -20° C ~ +85° C Mounting: Two (2) 5 mm mounting holes for #10 screws Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev A 05/2018 - Page: 1/1 Code S02-01H
BLR-I-604 价格&库存
很抱歉,暂时无法提供与“BLR-I-604”相匹配的价格&库存,您可以联系我们找货
BLR-I-604
    库存:125
