Type BLR-I-610
Fuse Block - Indicating
10 Pole – Regular Auto Blade
www.optifuse.com
(619) 593-5050
Specifications:
Fuse Type: Regular Auto Blade – APR, ANR Series
Max Current Rating: 30A per Circuit - 100A Max Input
Max Voltage: 32VDC
IP Rating: 40
Material:
Base: PBT
Terminals: Copper, tin plated
0.250” [6.3mm] Quick Connect Terminals
Cover: PC (Transparent)
Indicating LED – Red
Temperature Rating: -20° C ~ +85° C
Mounting: Two (2) 5 mm mounting holes for #10 screws
Mechanical Dimensions: Inches [mm]
Warning:
-Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical
arcing and/or flame.
-Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance.
Note: All specifications subject to change without notice.
Rev A 05/2018 - Page: 1/1
Code S02-01H
很抱歉,暂时无法提供与“BLR-I-610”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+728.431051+94.24200
- 10+650.6968010+84.18500
