BLS-I-310
BLS-I-310
    OPTIFUSE
    MINI LP FUSE BLOCK, 10 POLE LED
BLS-I-310 数据手册
Type BLS-I-310 Fuse Block - Indicating 10 Pole-Low Profile Mini Auto Blade www.optifuse.com (619) 593-5050 Specifications: Max Current Rating: 30A per Circuit - 100A Max Input Fuse Type: Low Profile Miniature Auto Blade – APS, ANS series Base: PBT (UL-Flame 94V-0), Black Cover: PC (UL-Flame 94V-2), Transparent Terminals: Tin Plated Brass - 0.250” Quick Connect Terminals Indicating LED – Red Temperature Rating: -20° C ~ +85° C Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev B 05/2017 - Page: 1/1 Code S02-01H
BLS-I-310 价格&库存
很抱歉,暂时无法提供与“BLS-I-310”相匹配的价格&库存,您可以联系我们找货
BLS-I-310
  • 1+482.127031+62.37600
  • 10+430.5953410+55.70900
