BMS
BMS
    OPTIFUSE
    PCB FUSEHOLDER, RADIAL LEAD FUSE
BMS 数据手册
Type BMS PCB Mounted Fuse Holder For Micro Fuses (FMS/TMS) www.optifuse.com (619) 593-5050 Specifications: PCB Mounted Fuse Holder Material: Thermoplastic, UL94-V0 Polyester PCT Terminal: Copper Alloy; solderable tinned Rating: 250V, 6.3A, 1.6W For use with Micro Fuses – FMS(-E) / TMS(-E) Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Fuse Holders are not intended for circuit disconnect. All power should be disconnected before removing fuse. -Avoid contact of Fuse Holder with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev C 04/2009 - Page: 1/1 Code J01-02D
很抱歉,暂时无法提供与“BMS”相匹配的价格&库存,您可以联系我们找货
