CBW28-1A
CBW28-1A
    OPTIFUSE
    FUSEHOLDER TYPE CB-TYPE III, 1A
CBW28-1A 数据手册
Type CBW28 Thermal Circuit Breaker Fuseholder Type – Push to Reset www.optifuse.com (619) 593-5050 Specifications: Fuseholder Type Circuit Breaker – Push to Reset Voltage: 125/250 VAC, 50/60 Hz. and 32 VDC Amperage: 1A, 1.25A, 1.5A, 1.75A, 2A, 2.25A, 2.5A, 3A, 3.5A, 4A, 5A, 6A, 7A, 8A, 9A, 10A, 11A, 12A, 13A, 15A, 16A Interrupt Capacity: 1000A @ 250 VAC, 50/60Hz. and 200A @ 32 VDC Insulation Resistance: 100M  Terminals: 0.250” [6.35mm] quick connect – Nickel plated brass. Panel Thickness: 0.8 – 2.1mm (0.031 - 0.083 inches) Mounting: Snap-In Front Panel Mount (See Recommended Cut Out) Agency Standards and Listings: Mechanical Dimensions: Inches [mm] Note: All specifications subject to change without notice. Rev F 02/2013 - Page: 1/2 Code K01-01H Type CBW28 Thermal Circuit Breaker Fuseholder Type – Push to Reset www.optifuse.com (619) 593-5050 Calibration: Electrical Data @ 25C Continuously Carried at 100% of Rated Current 1A-2.5A: May Trip between 101% to 149% 3.0A-16A: May Trip between 101% to 134% 1A-2.5A: Must Trip at 150% of Rated Current within 1 Hour 3.0A-16A: Must Trip at 135% of Rated Current within 1 Hour Ambient Compensation Chart Ambient Temperature Correction Factor: The time/current characteristic curve depends on the ambient temperature prevailing. In order to eliminate nuisance tripping. Please multiply the current breaker current ratings by the derating factor shown above. Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Device are intended for occasional overcurrent protection. Application for repeated overcurrent condition and/or prolonged trip are not anticipated. -Avoid contact of device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev F 02/2013 - Page: 2/2 Code K01-01H
CBW28-1A 价格&库存
很抱歉,暂时无法提供与“CBW28-1A”相匹配的价格&库存,您可以联系我们找货
CBW28-1A
  • 1+47.029211+6.10200
  • 20+43.8939320+5.69520
