CNM-05
CNM-05
    OPTIFUSE
    MINI PC BOARD FUSE CLIP, 15A
CNM-05 数据手册
Type CNM-05 PC Board Type Fuse Clip Mini Auto Blade Fuses www.optifuse.com (619) 593-5050 Specifications: Rating: 15A, 500VAC Body Material: Spring bronze Finish: Bright Tin-plated For use with Type APM Fuses (Mini-Automotive Blade Type) Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev C 08/2018 - Page: 1/1 Code G02– 01H
CNM-05 价格&库存
很抱歉,暂时无法提供与“CNM-05”相匹配的价格&库存,您可以联系我们找货
