CNR-01-CE
CNR-01-CE
    OPTIFUSE
    REGULAR FUSE CLIP, 15A MATTE
CNR-01-CE 数据手册
Type CNR-01 PC Board Type Fuse Clip Standard Auto Blade Fuses www.optifuse.com (619) 593-5050 Specifications: Amperage Part number: Material Voltage Rating: 500V AC / 250V DC Rating Amperage Rating: See Chart Spring 15A Max. CNR-01 Body Material: See Chart Bronze Finish: Bright Tin-plated Phosphor 20A Max. CNR-01-PCU (For Matte Tin-plated add –CE at end of Bronze part number …ie. CNR-01-PCU-CE) Beryllium For use with Type APR, ANR Fuses (Standard-Auto Blade Type) CNR-01-BECU Bronze 40A Max. Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev D 07/2018 - Page: 1/1 Code G02 – 01H
CNR-01-CE 价格&库存
很抱歉,暂时无法提供与“CNR-01-CE”相匹配的价格&库存,您可以联系我们找货
