CNR-03-CE
CNR-03-CE
    OPTIFUSE
    REGULAR FUSE CLIP, 30A MATTE
CNR-03-CE 数据手册
Type CNR-03-CE PC Board Type Fuse Clips Standard Auto Blade Fuses www.optifuse.com (619) 593-5050 Specifications: Rating: 30A, 500VAC Dielectric Strength for 60 seconds: AC1500V Min. Initial Insertion Force (Min./Max.): 1kg / 8 kg Initial Extraction Force (Min./Max.): 1kg / 10 kg Insertions: 25 Min. Initial Contact Resistance at 1A DC: 5mΩ Max. Insulation Resistance at 500V DC: 100MΩ Min. Initial Voltage Drop: 20mV Max. Temperature Rise: 50° C Max. Molded Base: Nylon with Glass Fiber (30%) (94V0) Terminals: Spring Bronze: C2680 Brass, H, Cu 68%, Zn 32%, 0.35t Plating: Matte Tin Plated - 3μ min. Operating Temp: -50° C to +145° C Storage Temp: -40° C to +80° C For use with Type APR, ANR Fuses (Standard-Automotive Blade Type) Mechanical Dimensions: Inches [mm] Note: All specifications subject to change without notice. Rev C 08/2018 - Page: 1/2 Code G02-01H Type CNR-03-CE PC Board Type Fuse Clips Standard Auto Blade Fuses www.optifuse.com (619) 593-5050 Mechanical Dimensions: Inches [mm] (continued) Dimensions < 0.039 [1] 0.039 ~ 0.315 [1 ~ 7.995] 0.315 ~ 0.984 [8 ~ 24.995] 0.984 ~ 3.937 [25 ~ 99.995] Warning: Tolerances ± 0.001 [0.03] ± 0.008 [0.2] ± 0.010 [0.25] ± 0.012 [0.3] -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev C 08/2018 - Page: 2/2 Code G02-01H
CNR-03-CE 价格&库存
很抱歉,暂时无法提供与“CNR-03-CE”相匹配的价格&库存,您可以联系我们找货
