CNR-06-SMD
CNR-06-SMD
    OPTIFUSE
    REGULAR PC BOARD FUSE CLIP, 40A
CNR-06-SMD 数据手册
Type CNR-06-SMD PC Board Type Fuse Clip Regular Auto Blade Fuses www.optifuse.com (619) 593-5050 Specifications: Rating: 30A 500 VAC / 125 VDC Body Material: PBT Contacts: Beryllium, Tin-plated For use with Regular Automotive Blade Fuses: APR, ANR Series Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications and dimensions subject to change without notice. Rev A 08/2018- Page: 1/1 Code G02-01H
CNR-06-SMD 价格&库存
很抱歉,暂时无法提供与“CNR-06-SMD”相匹配的价格&库存,您可以联系我们找货
