CNX-01-CE
CNX-01-CE
    OPTIFUSE
    MAXI PC BOARD FUSE CLIP, 60A
CNX-01-CE 数据手册
Type CNX-01 PC Board Type Fuse Clip Maxi Auto Blade Fuses Specifications: Voltage Rating: 500V AC / 250VDC Amperage Rating: See Chart Body Material: See Chart www.optifuse.com (619) 593-5050 Part number: Material Amperage Rating Brass Current up to 60A CNX-01 CNX-01-PCU Phosphor Bronze Current up to 80A CNX-01-BECU Beryllium Bronze Current up to 100A Finish: Bright Tin plated For Matte Tin plated – Add a -CE to end of part number (ie. CNX-01-PCU-CE) For use with Type APX Fuses - (Maxi Automotive Blade Type) Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev A 02/2014 - Page: 1/1 Code G02 – 01H
CNX-01-CE 价格&库存
很抱歉,暂时无法提供与“CNX-01-CE”相匹配的价格&库存,您可以联系我们找货
