CSA-01
CSA-01
    OPTIFUSE
    PCB FUSE CLIP - 1/4", END STOPS
CSA-01 数据手册
Type CSA-01 PC Board Type Fuse Clip ¼” Diameter Fuses with End Stops www.optifuse.com (619) 593-5050 Specifications: Rating: 15A, 250V AC Body Material: Spring Brass Finish: Bright Tin plated (For Matte Tin-plated add -CE at end of part number… i.e. CSA-01-CE) Fuse Clip with End Stops and Mounting pins For use with ¼” Diameter (6.3mm) Fuses Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev C 12/2015 - Page: 1/1 Code G02-01H
CSA-01 价格&库存
很抱歉,暂时无法提供与“CSA-01”相匹配的价格&库存,您可以联系我们找货
