CSA-06
CSA-06
    OPTIFUSE
    PCB FUSE CLIP - 1/4", END STOPS
CSA-06 数据手册
Type CSA-06 PC Board Type Fuse Clip ¼” Diameter Fuses with End Stops www.optifuse.com (619) 593-5050 Specifications: Rating: 15A, 250V AC Body Material: Phosphor Bronze Finish: Bright Tin plated Fuse Clip with End Stops For use with ¼” Diameter (6.3mm) Fuses Mechanical Dimensions: mm [Inches] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev A 07/2009 - Page: 1/1 Code J01-01H
CSA-06 价格&库存
很抱歉,暂时无法提供与“CSA-06”相匹配的价格&库存,您可以联系我们找货
