CSC-02
CSC-02
    OPTIFUSE
    PCB FUSE CLIP - 5MM, END STOPS
CSC-02 数据手册
Type CSC-02 Fuse Clip – with End Stops 5mm Diameter Fuses www.optifuse.com (619) 593-5050 Specifications: Rating: 10A, 250V AC Body Material: Bronze Finish: Tin Plated Fuse Clip Type: Ear Type with End Stops For use with 5mm Diameter Fuses Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. -Not designed for prolonged liquid exposure or submersible applications. Note: All specifications subject to change without notice. Rev B 04/2014 - Page: 1/1 Code J01-01H
CSC-02 价格&库存
很抱歉,暂时无法提供与“CSC-02”相匹配的价格&库存,您可以联系我们找货
