CSC-03
CSC-03
    OPTIFUSE
    PCB FUSE CLIP - 5MM, END STOPS
CSC-03 数据手册
Type CSC-03 Fuse Clip – with End Stops 5mm Diameter Fuses www.optifuse.com (619) 593-5050 Specifications: Rating: 10A, 250V AC Body Material: Bronze Finish: Bright Tin Plated Fuse Clip Type: With End Stops For use with 5mm Diameter Fuses Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev A 05/2014 - Page: 1/1 Code J01-01H
CSC-03 价格&库存
很抱歉,暂时无法提供与“CSC-03”相匹配的价格&库存,您可以联系我们找货
CSC-03
  • 1000+2.707601000+0.35030
  • 2000+2.445582000+0.31640
