CSG-01
CSG-01
    OPTIFUSE
    PCB FUSE CLIP-13/32", END STOPS
CSG-01 数据手册
Type CSG-01 Fuse Clip – with End Stops 13/32” (10.3mm) Diameter Fuses www.optifuse.com (619) 593-5050 Specifications: Rating: 30A, 250V AC Body Material: Spring Brass Finish: Bright Tin Plated Fuse Clip Type: With End Stops For use with 13/32” (10.3mm) Diameter Fuses Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. -Not designed for prolonged liquid exposure or submersible applications. Note: All specifications subject to change without notice. Rev C 09/2015 - Page: 1/1 Code G02-01H
CSG-01 价格&库存
很抱歉,暂时无法提供与“CSG-01”相匹配的价格&库存,您可以联系我们找货
CSG-01
