FCD-250MA
FCD-250MA
    OPTIFUSE
    D5.2xL20mm
    一次性保险丝(熔断) 250mA 250V
FCD-250MA 数据手册
Type FCD Fast Acting High Breaking Capacity 5 x 20 mm Ceramic Fuse www.optifuse.com (619) 593-5050 Agency Standards and Listings: Interrupt Ratings: 250mA ~ 16A 1,500A at 250V AC (All) 250mA ~ 16A 1,000A at 250V DC UL 250mA ~ 6.3A 10,000A at 250V AC UL Time Characteristics 210% 275% Rated Current MAX MIN MAX 30 10 2 250mA~4A min ms sec 30 10 3 5A~6.3A min ms sec 30 40 20 8A~10A min ms sec 30 40 20 >10A min ms sec 400% 1000% MIN MAX MAX 3 300 ms ms 3 300 ms ms 10 1 ms sec 10 1 ms sec 20 ms 20 ms 30 ms 40 ms Operating Temperature: -55ºC to +125ºC Material: Ceramic Body/Nickel Plated Brass Caps Lead Wire Ø0.65mm Diameter – 8A and less. Ø0.8mm Diameter – 8a~ 12A. Ø1.0mm Diameter – over 12A. Cartridge Part number Axial Lead Part number FCD-250mA FCD-315mA FCD-400mA FCD-500mA FCD-630mA FCD-800mA FCD-1A FCD-1.25A FCD-1.6A FCD-2A FCD-2.5A FCD-3.15A FCD-4A FCD-5A FCD-6.3A FCD-8A FCD-10A FCD-12 A FCD-12.5A FCD-15A FCD-16A FCD-P-250mA FCD-P-315mA FCD-P-400mA FCD-P-500mA FCD-P-630mA FCD-P-800mA FCD-P-1A FCD-P-1.25A FCD-P-1.6A FCD-P-2A FCD-P-2.5A FCD-P-3.15A FCD-P-4A FCD-P-5A FCD-P-6.3A FCD-P-8A FCD-P-10A FCD-P-12A FCD-P-12.5A FCD-P-15A FCD-P-16A Amper Nominal Melting e I2 t Rating A2 Sec 250mA 315mA 400mA 500mA 630mA 800mA 1A 1.25A 1.6A 2A 2.5A 3.15A 4A 5A 6.3A 8A 10A 12A 12.5A 15A 16A 0.0040 0.0142 0.0200 0.0309 0.0672 0.1210 0.2019 0.4489 1.243 2.204 1.995 4.271 12.22 24.20 51.30 102.2 204.7 360.5 407.6 602.5 642.7 Safety Approvals CCC CQC SEMKO VDE * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * UR/ BSI PSE KC CE CUR * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * Voltage Rating 250V Mechanical Dimensions: Inches [mm] Note: All specifications subject to change without notice. Rev G 04/2017 - Page: 1/2 Code: H01-01H Type FCD Fast Acting High Breaking Capacity 5 x 20 mm Ceramic Fuse www.optifuse.com (619) 593-5050 Part Number FCD TIME CURRENT CURVES Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Glass Fuse device are intended for occasional overcurrent protection. Application for repeated overcurrent condition and/or prolonged trip are not anticipated. -Avoid contact of Glass Fuse device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev G 04/2017 - Page: 2/2 Code: H01-01H
FCD-250MA 价格&库存
很抱歉,暂时无法提供与“FCD-250MA”相匹配的价格&库存,您可以联系我们找货
