Type FCD
Fast Acting High Breaking Capacity
5 x 20 mm Ceramic Fuse
www.optifuse.com
(619) 593-5050
Agency Standards and Listings:
Interrupt Ratings:
250mA ~ 16A
1,500A at 250V AC (All)
250mA ~ 16A
1,000A at 250V DC UL
250mA ~ 6.3A 10,000A at 250V AC UL
Time Characteristics
210%
275%
Rated
Current
MAX MIN MAX
30
10
2
250mA~4A
min ms sec
30
10
3
5A~6.3A
min ms sec
30
40 20
8A~10A
min ms sec
30
40 20
>10A
min ms sec
400%
1000%
MIN MAX
MAX
3 300
ms ms
3 300
ms ms
10 1
ms sec
10 1
ms sec
ms
ms
30
ms
40
ms
Operating Temperature:
-55ºC to +125ºC
Material:
Ceramic Body/Nickel Plated Brass Caps
Lead Wire Ø0.65mm Diameter – 8A and less.
Ø0.8mm Diameter – 8a~ 12A.
Ø1.0mm Diameter – over 12A.
Cartridge
Part number
Axial Lead
Part number
FCD-250mA
FCD-315mA
FCD-400mA
FCD-500mA
FCD-630mA
FCD-800mA
FCD-1A
FCD-1.25A
FCD-1.6A
FCD-2A
FCD-2.5A
FCD-3.15A
FCD-4A
FCD-5A
FCD-6.3A
FCD-8A
FCD-10A
FCD-12 A
FCD-12.5A
FCD-15A
FCD-16A
FCD-P-250mA
FCD-P-315mA
FCD-P-400mA
FCD-P-500mA
FCD-P-630mA
FCD-P-800mA
FCD-P-1A
FCD-P-1.25A
FCD-P-1.6A
FCD-P-2A
FCD-P-2.5A
FCD-P-3.15A
FCD-P-4A
FCD-P-5A
FCD-P-6.3A
FCD-P-8A
FCD-P-10A
FCD-P-12A
FCD-P-12.5A
FCD-P-15A
FCD-P-16A
Amper Nominal
Melting
e
I2 t
Rating A2 Sec
250mA
315mA
400mA
500mA
630mA
800mA
1A
1.25A
1.6A
2A
2.5A
3.15A
4A
5A
6.3A
8A
10A
12A
12.5A
15A
16A
0.0040
0.0142
0.0200
0.0309
0.0672
0.1210
0.2019
0.4489
1.243
2.204
1.995
4.271
12.22
24.20
51.30
102.2
204.7
360.5
407.6
602.5
642.7
Safety Approvals
CCC CQC SEMKO VDE
UR/
BSI PSE KC CE
CUR
Voltage
Rating
250V
Mechanical Dimensions: Inches [mm]
Note: All specifications subject to change without notice.
Rev G 04/2017 - Page: 1/2
Code: H01-01H
Type FCD
www.optifuse.com
(619) 593-5050
Part Number FCD
TIME CURRENT CURVES
Warning:
-Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame.
-Glass Fuse device are intended for occasional overcurrent protection. Application for repeated overcurrent condition and/or prolonged trip
are not anticipated.
-Avoid contact of Glass Fuse device with chemical solvent. Prolonged contact will damage the device performance.
Rev G 04/2017 - Page: 2/2
Code: H01-01H
很抱歉,暂时无法提供与“FCD-P-3.15A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+15.36840
- 200+5.95080
- 500+5.74560
- 1000+5.63760
