FSD-500MA
FSD-500MA
    OPTIFUSE
    D5.2xL20mm
    一次性保险丝(熔断) 500mA 250V
FSD-500MA 数据手册
Type FSD Fast Acting Glass Tube Fuse 5 x 20 mm www.optifuse.com (619) 593-5050 Agency Standards and Listings: Nominal Cartridge Part number Axial Lead Ampere Melting I2 t Part number Rating 2 A Sec Interrupt Ratings: 35A or 10In whichever is greater (63mA-16A) @ 250V AC Time Characteristics Rated Current 210% 275% 400% 1000% MAX MIN MAX MIN MAX MAX 30 min 30 125mA~6.3A min 30 8A~10A min 30 12A~16A min 30 >16A min 63mA~100mA 10 ms 50 ms 50 ms 50 ms 100 ms 500 ms 2 sec 2 sec 3 sec 6 sec 3 ms 10 ms 10 ms 10 ms 20 ms 100 ms 300 ms 400 ms 400 ms 600 ms 20 ms 20 ms 40 ms 50 ms 60 ms Operating Temperature: -55ºC to +125ºC Material: Glass Body/Nickel Plated Brass Caps Lead Wire Ø0.65mm Diameter – 8A and less Ø0.8mm Diameter – 8A ~ 15A Ø1.0mm Diameter – over 15A FSD-63mA FSD-80mA FSD-100mA FSD-125mA FSD-160mA FSD-200mA FSD-250mA FSD-315mA FSD-400mA FSD-500mA FSD-630mA FSD-750mA FSD-800mA FSD-1A FSD-1.25A FSD-1.6A FSD-2A FSD-2.5A FSD-3.15A FSD-4A FSD-5A FSD-6.3A FSD-8A FSD-10A FSD-12 A FSD-12.5A FSD-15A FSD-16A FSD-20A FSD-P-63mA FSD-P-80mA FSD-P-100mA FSD-P-125mA FSD-P-160mA FSD-P-200mA FSD-P-250mA FSD-P-315mA FSD-P-400mA FSD-P-500mA FSD-P-630mA FSD-P-750mA FSD-P-800mA FSD-P-1A FSD-P-1.25A FSD-P-1.6A FSD-P-2A FSD-P-2.5A FSD-P-3.15A FSD-P-4A FSD-P-5A FSD-P-6.3A FSD-P-8A FSD-P-10A FSD-P-12A FSD-P-12.5A FSD-P-15A FSD-P-16A FSD-P-20A 63mA 80mA 100mA 125mA 160mA 200mA 250mA 315mA 400mA 500mA 630mA 750mA 800mA 1A 1.25A 1.6A 2A 2.5A 3.15A 4A 5A 6.3A 8A 10A 12A 12.5A 15A 16A 20A 0.0008 0.0013 0.0018 0.0085 0.0099 0.0256 0.0272 0.0820 0.1224 0.2050 0.5505 0.7780 0.5747 1.240 1.810 3.200 7.256 13.69 22.33 35.19 58.83 104.6 185.6 244.4 428.5 473.1 838.8 894.7 1877 Safety Approvals CCC CQC SEMKO VDE UR/ CSA BSI CUR ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● PSE KC IMQ ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● Voltage Rating ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● 250V Mechanical Dimensions: Inches [mm] Note: All specifications subject to change without notice. Rev D 12/2015 - Page: 1/2 Code: H01-01H Type FSD Fast Acting Glass Tube Fuse 5 x 20 mm www.optifuse.com (619) 593-5050 Part Number FSD TIME CURRENT CURVES Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Glass Fuse device are intended for occasional overcurrent protection. Application for repeated overcurrent condition and/or prolonged trip are not anticipated. -Avoid contact of Glass Fuse device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev D 12/2015 - Page: 2/2 Code: H01-01H
FSD-500MA 价格&库存
很抱歉,暂时无法提供与“FSD-500MA”相匹配的价格&库存,您可以联系我们找货
