Battery Disconnect
HDB2-1A-3-A1
Mechanical Dimensions: Inches [mm]
Tolerances ±0.012 [0.3] Unless Otherwise Specified
Mounting Hole
Circuit Diagram
SPST: Does not disconnect alternator
0.6[ .0]
.7[
0.2
0.7[
or generator field circuit.
.0]
Electrical Specifications
Materials Specifications
Continuous Rating
300A 6-32VDC
Steel construction
Intermittent Rating
2000A for 5secs intervals
Sealed with O-rings at base and mounting stem
Inrush Rating
1000A for 30secs intervals
Case and terminal insulator
Insulation Resistance
DC 500V 100M ohm Min
Copper terminals
Dielectric Strength
AC 1000V 1 minute
IP67
Rev A 11/2019
Battery Disconnect
Rev
A
HDB2-1A-3-A1
Designed Approved
Date of issue Revision Notes
11-12-2019
Initial Drawing
RC
Rev A 11/2019
OF
很抱歉,暂时无法提供与“HDB2-1A-3-A1”相匹配的价格&库存,您可以联系我们找货
