Battery Disconnect
HDB3-2A-3-A
Mechanical Dimensions: Inches [mm]
Tolerances ±0.012 [0.3] Unless Otherwise Specified
Mounting Hole
Circuit Diagram
0.6[
7[
0.6
0.
0.8[
DPST: For battery and alternator or
generator field circuit.
Electrical Specifications
Material Specifications
Intermittent Rating
180A 6-36VDC (Large Studs),
20A 6-36VDC (Small Studs)
1000A for 15secs intervals
Sealed with O-rings at base and mounting stem
Insulation Resistance
DC 500V 100M ohm Min
Copper, Silver plated terminals
Dielectric Strength
AC 1000V 1 minute
Operation Temperature
-40°C~85°C
Continuous Rating
Zinc diecast construction
Rev A 11/2019
Battery Disconnect
Rev
A
HDB3-2A-3-A
Designed Approved
Date of issue Revision Notes
11-12-2019
Initial Drawing
RC
Rev A 11/2019
OF
很抱歉,暂时无法提供与“HDB3-2A-3-A”相匹配的价格&库存,您可以联系我们找货
