LPK-08
LPK-08
    OPTIFUSE
    MICRO3 ADD-ON FUSEHOLDER, 2 CKT
LPK-08 数据手册
Type LPK-08 “Add-On” Automotive Fuse Holder Micro, 3-Leg Auto Blade Type Fuse www.optifuse.com (619) 593-5050 Fuse Type: Micro, 3-Leg Automotive Blade - ANK Fuse Series Rating: 58VDC Max Combined Current - Both Circuits - 30A Max Existing Circuit - 20A Max Add-on Circuit - 15A Body Material: Nylon PA66 UL 94V-0 Terminals: Tin Plated Brass Wire: 16 AWG UL1015 Red Wire Connector: Butt-Splice Connector Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Device is intended for occasional overcurrent protection. Application for repeated overcurrent condition and/or prolonged trip are not anticipated. -Avoid contact of device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications and dimensions subject to change without notice. Rev A 04/2017 - Page: 1/1 Code G02-01H
LPK-08 价格&库存
很抱歉,暂时无法提供与“LPK-08”相匹配的价格&库存,您可以联系我们找货
