LPM-04B-I-12R
LPM-04B-I-12R
    OPTIFUSE
    MINI FUSEHOLDER, 30A-12AWG LED
LPM-04B-I-12R 数据手册
Type LPM-04B-I In-Line Fuse Indicating Holder Mini. Auto Blade Fuses Waterproof Ratings: Fuse Type: Mini Auto Blade – APM, ANM Electrical Rating: see Wire Gauge table Body: PVC Contacts: Tin plated Brass IP Rating: IP67 With LED warning light when fuse is opened. Standard Wire Gauges: #12 ~ #18 AWG Standard Wire Colors: Red Standard Body colors: Black Standard Wire Length: 4 inches www.optifuse.com (619) 593-5050 Standard Wire Gauges Wire Gauge Rating Wire Color #12 30A 24VDC Red #14 20A 24VDC Red #16 15A 24VDC Red #18 10A 24VDC Red Part number format LPM-04B-I-##R where ## = Wire gauge Available in various wire gauges and lengths, and wire colors. Contact factory for those not listed above. Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. -Not designed for prolonged liquid exposure or submersible applications. Note: All specifications subject to change without notice. Rev A 07/2018 - Page: 1/1 Code S02-02D
LPM-04B-I-12R 价格&库存
很抱歉,暂时无法提供与“LPM-04B-I-12R”相匹配的价格&库存,您可以联系我们找货
