LPM-05B-12R
LPM-05B-12R
    OPTIFUSE
    MINI FUSEHOLDER, 30A-12AWG RED
LPM-05B-12R 数据手册
Type LPM-05 Water-Proof In-Line Fuse Holder Automotive Mini. Blade Type www.optifuse.com Specifications: Rating: 32VDC Body/Cap Material: Polycarbonate Seal Material: Silicon rubber Contacts: Bronze, Tin/Nickel plated IP Rating: IP67 For use w/ Type APM, ANR Fuse (Miniature Automotive Blade) Water-proof with Inter-Locking Cap Attached Mounting Bracket Standard Wire: #12, #14, #16 AWG – 12” Loop - Red Color (Other wire sizes and colors available as special order) (619) 593-5050 Part number format LPM-05B-##R Where ## = Wire Gauge (12,14,16 AWG) Wire Gauge 12 AWG 14 AWG 16 AWG Max. Amperage 30 A 20 A 15 A Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Device are intended for occasional overcurrent protection. Application for repeated overcurrent condition and/or prolonged trip are not anticipated. -Avoid contact of device with chemical solvent. Prolonged contact will damage the device performance. - Not intended for submersible water applications. Note: All specifications subject to change without notice. Rev A 07/2018 - Page: 1/1 Code B01-01H
LPM-05B-12R 价格&库存
很抱歉,暂时无法提供与“LPM-05B-12R”相匹配的价格&库存,您可以联系我们找货
LPM-05B-12R
  • 100+110.05074100+14.23800
  • 200+98.69630200+12.76900
