LPX-04B-I-6R
LPX-04B-I-6R
    OPTIFUSE
    MAXI FUSEHOLDER, 60A-6AWG LED
LPX-04B-I-6R 数据手册
Type LPX-04B-I In-Line Indicating Fuse Holder Maxi Auto Blade Fuses Waterproof Ratings: Fuse Type: Maxi Auto Blade – APX Electrical Rating: 20A-60A 24VDC IP Rating: IP66 Body: PVC Contacts: Tin plated Brass With LED warning light when fuse is opened. Standard Wire Gauges: #6 AWG Standard Wire Colors: Red Standard Body colors: Black Standard Wire Length: 5 inches www.optifuse.com (619) 593-5050 Part number format LPX-04B-I-##R where ## = Wire gauge Available in various wire gauges and lengths, and wire colors. Contact factory for those not listed above. Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. -Not designed for prolonged liquid exposure or submersible applications. Note: All specifications subject to change without notice. Rev A 03/2008 - Page: 1/1 Code S02-02D
LPX-04B-I-6R 价格&库存
很抱歉,暂时无法提供与“LPX-04B-I-6R”相匹配的价格&库存,您可以联系我们找货
LPX-04B-I-6R
  • 100+186.03815100+24.06900
  • 200+166.82294200+21.58300
