MOCB-12-V-40A
MOCB-12-V-40A
    OPTIFUSE
    VER. BRACKET-TYPE II MOD,40A 12V
MOCB-12-V-40A 数据手册
Type MOCB-12-V / MOCB-24-V Modified Reset Circuit Breaker Automotive Type II Metal With Vertical Bracket www.optifuse.com (619) 593-5050 Specifications: Modified Reset Type Circuit Breaker. Modified reset circuit breakers are devices that are opened by over-current and remain open as long as the power is on to the affected circuit or until load is removed Voltage: 12V or 24V Amperage: 10A, 15A, 20A, 25A, 30A, 35A, 40A, 50A Terminals: Battery – Copper Plate (0.58”), Auxiliary – Zinc Plate (0.66”) Conforms to American National Standard SAE J553 Cover Material: Metal Operating Temperature: -10º F ~ 150º F Storage Temperature: -20º F ~ 200º F Current Rating: Rating 100% ± 1.5% 135% ± 1.5% 200% ± 1.5% Open Time > 30 Min < 30 Min < 1 Min Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Device are intended for occasional overcurrent protection. Application for repeated overcurrent condition and/or prolonged trip are not anticipated. -Avoid contact of device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev C 07/2012 - Page: 1/1 Code Y01-02D
MOCB-12-V-40A 价格&库存
很抱歉,暂时无法提供与“MOCB-12-V-40A”相匹配的价格&库存,您可以联系我们找货
